I've got this guy who has taken the pics from a powerpoint presentation and put them into separate floders as jpg files. Problem is, when he plays them on a dvd player that plays jpg's the files are completely in the wrong order. Now, my suggestion was to reburn the files as just a constant stream of jpg's and record them as data files in the order he wants them viewed in. He is going to try that and see if the player recognizes the correct order but I wanted to see if there was a better solution to this problem?
Most players with a slideshow-type JPG playback put them in some sort of order, be it alpha or numeric. You should just be able to figure out its order and rename the files.
Or, as an option, use MemoriesOnTV software to create a really cool MPEG / DVD slide show.
XMP – Metadata related question
By pavinm in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2010, 14:53 -
A question related to sub files and resized avi with AGK
By loninappleton in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2009, 22:35 -
DTV converter box, screen size-related question
By Ai Haibara in forum DVB / IPTVReplies: 6Last Post: 22nd Nov 2008, 18:18 -
Fraps and Ventrilo Related Question
By combatsimulation in forum AudioReplies: 0Last Post: 23rd Feb 2008, 19:05 -
You Tube related question
By bja5150 in forum ComputerReplies: 2Last Post: 24th Dec 2007, 10:39
