I have this avi file and I wanna convert it to DVD and I know how to do it but it always ends up beign full screen. How do I make it wide screen using TMPGEnc?!
First page of the Project Wizard. Do you have TMPGEnc or TMPGEnc Plus?
Here's screenshots of both:
https://www.videohelp.com/toolsimages/standardtool1.jpg
https://www.videohelp.com/toolsimages/standardtool278.jpg -
Oh, yeah... if your source AVI is 4:3 format to start with, you'll have to letterbox crop the image to 16:9 aspect ratio and then resize to work properly when "stretched" by the your DVD player. Unless you're talking about DV camcorder footage shot in 16:9 mode... which is already the right shape for 16:9 stretching.
Mine dosnt even have that option for 16:9. Maybe I needa download the latest version?
You probably need to update to the latest version. Do you have the Project Wizard disabled? I'm pretty sure that it can be shut off and won't come back unless you re-select it as a start up preference...
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Make Widescreen HD into Fullscreen like my blu ray player does
By PSS2 in forum Video ConversionReplies: 8Last Post: 22nd Mar 2011, 03:04 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15 -
Cutting 4:3 Top & Bottom, to make 16:9 Widescreen
By bibi in forum Newbie / General discussionsReplies: 3Last Post: 12th Jul 2007, 23:48
