Hi All
I have here an Mpeg file which is 718.8MB a few Meg over the limits of an 80 Min CDR, before I go down the road of buying a couple of 90 Min CD's which I assume that I can burn on a basic eMac, is there anyway that I can do an overburn to get this to fit?
Washac
there is indeed
author it as VCD/SVCD based on it being a MPEG1/MPEG2 respectfully
then burn it as you would a VCD/SVCD and it will fit perfectly onto a 700 meg cdr
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Font size is sometimes big and sometimes small
By Fire Foxer in forum SubtitleReplies: 0Last Post: 25th Aug 2010, 15:23 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14 -
Can a QT file get as small as a WMV?
By Antoniola in forum MacReplies: 6Last Post: 22nd May 2008, 01:13 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
