i have gotten this error message "Playback Prohibitied by Area Limitations" this only happens on my sony and panasonic, the same discs would play on myy apex and klh though.
Rencoding the movie through DVDShrink usuually fixed this problem. except recently i had the Centropy release of Harry Potter 3 and it had the same error message, and after reenciding it thorugh DVDShrink it still doesnt work.
is the error message "PLayback Prohibitied by Area Limitations" an indication of wroing region or PAL?
thanks for any help
Look on the left "DVD Hacks". See if your DVD players are listed. Many DVD players can be "hacked" to make them region free. Name brands like Sony or Panasonic are less likely to have hacks.
If you still have the disk try ripping with DVD Decrypter to your HD before using DVD Shrink. DVD Decrypter will make it region free. -
Any reason why you have to mention your movie is warez?
yeah i thought of that too while i was typing, i found it odd that such a big group would release something not totally universal, also i aquired a different cut of the same movie and only 1.5 gigs, with the same region error.
also does anyone know th esource or method of these 1.5 gig DVD-r movies, usually TS or cam
thanks -
i thought shrink did that too, it just seems not to work all the time.
do i have to change any setting in decrypter, or all the de-regioning. and if all dvd's are ripped by decrypter thank hacking my Sony player will be unessary?
"If you still have the disk try ripping with DVD Decrypter to your HD before using DVD Shrink. DVD Decrypter will make it region free." -
One more question.... (I usually dont have any problems with software)
Is it possible to rip/encode a movie with DVDdecrypter from a VIDEO_TS directory on your hardrive? this is the function of the "open files" button on dvdShrink. Or is it only from a phsical DVD disc?
play back prohibited by area limitations
By tron1980 in forum Newbie / General discussionsReplies: 1Last Post: 13th Apr 2012, 22:21 -
How to remove or disable area limitations on Sony DVD player?
By coody in forum DVD RippingReplies: 22Last Post: 25th Feb 2012, 03:21 -
Area Limitations
By jmsrickland in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2007, 21:10 -
Playback prohibited by area limitations >8(
By Flare in forum MacReplies: 3Last Post: 17th Jul 2007, 17:38 -
Sudden "Playback prohibited by area limitations." problem
By ph1losophe in forum Authoring (DVD)Replies: 11Last Post: 16th Jul 2007, 22:46
