I've found the best way to get my analogue footage copied is via my standalone recordable DVD Player, doing it via the PC gives awful results despite having an XP3200.
Once I have the DVD I want to open it in Windows Movie Maker to add transitions etc. WMM won't open the .vob file though, neither will clone DVD, Virtual Dub will open the file but playing back the preview screen shows awful lines & a blocky image, even though I'm not choosing any compression, When I do a small smaple it's awful.
TMPGenc will open the file when I change the extension from .vob to .mpg but will then promptly crash.
Does anyone know how I can get this vob file into a position to edit it normally. The same goes for films I record on the DVD, I can't edit anything down. It's a Yamada DVD Recordable if anyone has experianced the same troubles?
Thanks for any help.
Steve
use DVDdecrypter in file mode. enable stream processing and demux your video and audio streams. edit to your hearts content.
https://www.videohelp.com/forum/viewtopic.php?t=224833
and this is NOT capturing. i'm moving you.
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 08:00 -
vob and mpeg to dvd
By Dekaspace in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2008, 18:36 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08
