I'm trying to convert my dvd to xvid, and although the ac3 states that there is a 0 second delay, when merging the audio/video, the sync is off.
I have headac3che, and I am given the delay (ms) option, but first, how do I determine that the actual delay is?
I've never ran into this sort of problem before, therefore, I can see myself trying 1 ms at a time, but that would take FOREVER to convert, especially if the sync remains off.
Please help!
There's a tool called PVAStrumento. It's used for listing the PTS time stamp values in an MPEG file. It can also repair them theoretically, for correcting lip-sync issues, but I've never had any luck doing that. It does give you a very verbose accounting of the time values in the file, if desired, and you can select the level of detail you want.
Thanks for the suggestion; however, it doesn't seem to be working. It constantly crashes through the 'scan' option.
I now have 3 movies that are out of sync, and all i need to find is a program to determine when to 'delay' the audio so it's in sync.
Any other thoughts? -
You can use VirtualDub to determine the audio delay. Open the video in VirtualDub then:
-Audio -> Interleaving
Then go down to Audio Skew and fiddle with it until you've got a idea of where you want it. -
I sympathize. I fought the sync battle for months 2 years ago. It's so difficult to fix after the fact, but so easy to avoid with a TBC.
I got to the point where I was demuxing the PS, taking the audio and converting to .WAV, using a special command line app to resample the audio with the desired delay, converting back to MP2 audio, remuxing, andn authoring. It never worked because my sync problem was not linear - the video clip would start out 10 mS out of sync and slowly drift more and more until at the 2 hour point it was 0.5 seconds off. The app I tried was hit or miss and I really had hope because you could resample the audio with any duration - stretch or compress. The problem was I needed to stretch it less at the beginning and more at the end. I never did get it right. That was when I bought my Timebase Corrector and the problem vanished.
Since I never did find a method that works, I can't suggest anything except "don't capture out of sync", but that doesn't help you. :P
Audio out of sync, how to determine delay needed.
By mattstan in forum Authoring (DVD)Replies: 9Last Post: 23rd Dec 2019, 03:26 -
How to determine good audio levels in videos - Various formats
By rockerguy82 in forum Newbie / General discussionsReplies: 0Last Post: 12th Mar 2012, 12:15 -
Audio delay reported in MKV and what to do with it when adding new audio
By pascal in forum AudioReplies: 14Last Post: 30th Dec 2011, 12:07 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
Audio delay.. can anyone help?
By denadel in forum AudioReplies: 5Last Post: 31st Dec 2007, 12:14
