Results 1 to 18 of 18
  1. 2 questions...
    First, when someone has a fever, when should he consider going to the doctor? (I ask because I have a temp of 38 degrees celcius...and feel like crap) I haven't had a fever in ages.
    Second, how is it that a thermometer can acuratly take your body temp from your mouth, arm pit and ass??
    SmileSmile
  2. Member Treebeard's Avatar
    Aug 2002
    Well that is slightly over 100 degrees F. so you dont need to go yet. and you dont get accurate measurements from the armpit you have to add a few degrees to it, I have kids.. you learn these things
  3. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Yep, the most acurate is unfortunately....rectally. The new ear thermometers are pretty good though, and fast. Ours is stuck on C, and we can't get it back to F, so I wrote a small web service that my wife uses for the conversion when she needs to.
    For an adult, I wouldn't worry until about 103 (you do the math).
  4. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Originally Posted by beavereater
    2 questions...
    Sorry you're ill.
    Arm-pit is slightly cooler. The mouth and the ass are accurate because the blood vessels are close to the surface there and the thermometer is really reading a temp closer to the real temp of your blood.
    I would start getting concerned when it gets to 102.5F.
  5. Thanks...well, hope the meds work. I don't mind being sick, it happens. If I have a cold, I can deal with it...but having a fever, I feel weak, and when I feel weak I get scared!! IT SUCKS
    SmileSmile
  6. Member 888888's Avatar
    Jan 2004
    Turdistan
    2 questions...
    Stay off the Shabu good buddy.
  7. Originally Posted by 888888
    2 questions...
    Shabu??? Are you talking about shabu shabu...the dish!?
    SmileSmile
  8. Get well soon.... a few shots of whisky never hurts and helps you sleep.
  9. Ummm, the normal and high are different for everybody. The generaly excepted norm is 98.6F / 37C. My normal temp is 96.9F and if I get to 100F there is something wrong! I always tell doctors and nurses my normal temp before they take my current temp...When I'm sick, I know I'm sick. I don't want a doctor or a nurse tellying me that I'm not becuase my temp isn't high enough to them.
    Originally Posted by jagabo
  10. Most digital thermometers are calibrated so they give an accurate temperature orally.
    But should you take a temp axially (armpit) then you must add .9 degrees F. Anally you must subtract .9 degrees F.
  11. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    The ear therms. are really great, but you have to make sure they are in correctly and that there is no open gaps. It's very quick and fairly accurate. The mouth is a bit slower, but is very accurate. It's slow because it's meant to expell heat. Rectal, is the best for core temperature. It tends to be a bit warmer in the clostial oven. Usually the time to see the doctor is if your fever hits about 103F. Or if you've been above 101F for more than 8-12hrs. consecutively. Try taking anti-inflamatories at 1/2 dose and fever reducers at regular dose and it should help you feel a little better. My wife works for a health insurance company and that's what the doctors always say knocks out fevers the best.
  12. Update!! With the help of some strong (legal in Canada but who knows about Japan) meds...my temp has gone down to 36.8
    Now lets see where the lady hide my beer!!
    SmileSmile
  13. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    If she hid it in a cupboard outside of the fridge, you're best going to the store and getting a cold one. Unless you're german, then you might like warm beer, but nobody's perfect. :P
  14. Anonymous
    Guest
    dude you get sick alot. U need to partay more
  15. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Here's a tip, make sure you keep it in that order.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  16. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Always wise advice, tweedledee
  17. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    What if you know someone that has all three orifices in the same spot?
