Hello All!
I guess this might have been already answered here, but here it goes.
Does anybody know why appears a thin strip at the bottom of the captured image, that has nothing to do with the video?![]()
How can I remove it?
Thank you!
Best regards,
Joelson. -
Hello,
I think I know what you're talking about. I have a hauppauge wintv pvr250 card and I occasionally get the same thing. When I capture at dvd mode I sometimes get a small black line on the left and/or bottom of the screen.
I wouldn't worry about this. When I author it to dvd and burn it the lines are gone and converted to full screen. Your only problem may be if you intend only to watch it on your computer. You may want to convert it to divx or some other format to resize (and save space
). I hope this helps.
Kevin
P.S. This may be some sort of "ghosting" when recording from a rca video cable (the old standard yellow one). When I record from a svideo input from a dvd player I don't get this disturbance.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Overscan, it's on nearly any video, tv or whatever. I'ts not visible on a tv because it's off the viewable area of the TV. Unless your using your video for the computer forget about it. Media studio pro will crop it as will other editing software or just cover up with a black overlay to make it look neat.
Thin depth of field...?
By thiskey in forum Newbie / General discussionsReplies: 8Last Post: 19th Oct 2010, 13:12 -
Vob files image long and thin
By audio_head in forum Video ConversionReplies: 2Last Post: 2nd Mar 2010, 09:49 -
Thin or flat coax cable....does it work ok?
By hygieneboy in forum Off topicReplies: 4Last Post: 29th Aug 2009, 22:28 -
Conversion by changing video resolution results in a bottom rainbow strip
By usta in forum Video ConversionReplies: 3Last Post: 17th Jun 2009, 04:59 -
very very thin letterbox
By mark o in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 17:17
