I used vobedit to demux the video, audio, and subtitles; then used BeSweet to convert to ac3 file to dts; then used ReJig to author the original video, chapters, subtitles, and new dts track but the forced subtitles don't show up when I play it on my dvd player. Any help would be much appreciated.
Hello,
I don't work with subtitiles but here's a suggesion, do you have your closed caption feature turned on on your tv? (if this for your pc ignore this suggestion).
If this suggestion is too simplified please try a search for subtitles in the guide section on this site, maybe they can give you an idea your missing. Good luck.
No! The subtitles that aren't showing up are the "forced" alien language subtitles on SWEP1 -The Phantom Menace. They display when I play my original disk but not after I back-up and reauthor.
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Dark City Project-Edit AC3 soundtrack
By apostrophe in forum EditingReplies: 8Last Post: 24th Apr 2010, 00:06 -
How Do I Replace One Soundtrack With Another, mp4/aac file?
By mcompton69 in forum AudioReplies: 4Last Post: 4th Apr 2010, 19:26 -
mkv -> m4v with AC3 soundtrack problem
By jamesmac in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2008, 17:54 -
lipsync AC3 soundtrack?
By shun in forum AudioReplies: 4Last Post: 24th Feb 2008, 12:10
