I am having problem converting 1-hour avi 12.8 GB into svcd using tmpgenc, the produced video is always interlaced, I used the guide in here with exact settings
480x480 23,976 fps, Non-interlace (progressive), 1:1 VGA, Full screen (keep aspect ratio), 2077 bitrate and the same result, I then tried many other settings and still no changes. Are these settings correct ?
Thanks for any help.
could you do a screen grab of the first settings tab and the second one? or are you using the wizard?
ok i was using the wizard but of course i made changes as described in the guide but i can post snapshot of current settings when i go back home.
Originally Posted by Gondor
If that is the case and you intend to display this on a TV, then you should encode it interlaced, bottom field first. Oh, and it should be 29.97fps.
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48 -
interlaced pc/TV
By pantsdavies in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2007, 20:58 -
keep interlaced footage on tmpgenc xpress
By kamaleon in forum Video ConversionReplies: 2Last Post: 6th May 2007, 09:31
