I burned a DVD a while back with some Mpeg1 videos which were smooth, but lacked the detail. I also had some Mpeg2 vids which had great detail, but had bad jittering.
What can I do to keep the good quality, but lose that jitter?
TIA
Lance -
Edit: I misunderstood
but look in the guides section on the left, they'll show you how to change any kind of file into a dvd. -
incorrect.All dvds are mpeg2 format
Mpeg1 is allowed in the DVD spec. It is however rare.
* copy dvd to the hardrive.
* if 'jittering' stops it is shitty media. - get better disk and do again
* if 'jittering' persists, you may have reversed your fields when you encoded into mpeg2.
Options : reencode = lossy
I dimly remember another program that reverses fields .... will search.
......was thinking of : ReStream - http://shh.sysh.de/
I don't think it will work for you though. Reencoding (or better still encode the original again) appears to be the only option for reversed fields if that turns out to be the problem.
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 20:49 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 18:39 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 01:08 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 13:08 -
Why Does One Mpg Jitter and One Doesn't? And Why The Jitter?
By abrogard in forum Video ConversionReplies: 10Last Post: 17th Nov 2007, 02:21
