i have the CD Stomper kit. I ran out of the matte type labels and was thinking about getting the glossy ones. The picture should be better on the glossy ones but do they stick well on the dvd? Any advantages of using the glossy ones over the matte? thanks
Results 1 to 10 of 10
Glossy looks better.Originally Posted by rubbermanHello.
Sure glossy looks better but havent you seen the warning posts about labels and dvd's not playing....
Not bothered by small problems...
Spend a night alone with a mosquito -
There's a humongous thread about labels vs no labels, so go there for that. As for glossy labels, I use them and they look great and have no problems sticking. They're as sticky as matte or regular labels.
I use the CD stomper labels with no problems. You do get better results with the glossy, but, the glossy labels are thinner and you can see the disk's silkscreened logos through them. If your disks have no logos, you're in good shape.
If it works, don't fix it. -
Has anyone used the generic CD stomper labels on Ebay? They have 50 glossy labels for $4.99.
I got myself some and they are barely what would be considered glossy. I used to get the glossy neato and got the glossy cd stomper and they've been ok. The quality isn't as good but they still do the job alright and they seem to fit cds and dvdrs a little bit better than the neato ones.
Is there a free program out to print on the neato labels since those are positioned different than the CD Stomper?
I use the Neato mediaface software, free from neato.com or download.com. It has templates for all their labels.
Taiyo Yuden Watershield DVD-R 16x Glossy
By gold2040 in forum MediaReplies: 3Last Post: 27th Feb 2010, 15:26 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 08:06 -
Glossy or Antiglare Screen, which do you choose?
By elgemo in forum MacReplies: 9Last Post: 7th Mar 2008, 21:41 -
Photoshop filter/plugin - glossy light effect?
By Ai Haibara in forum ComputerReplies: 2Last Post: 30th Jan 2008, 19:39 -
Verbatim glossy DVD-R?
By spiffy in forum MediaReplies: 1Last Post: 28th Jun 2007, 11:51
