I've some RM files that can't be play by XBMC althought should be support since they are RV40 codec but then no video just sound. They all play perfectly ok on my pc. Since it's only a few files I thought that I will try to look for tools that can convert or encode RV40 files into other RM format, but have had no luck finding such tools. I then tried to use EO Video to convert them to Xvid but then the video still not working on the Xvid files
Can I ask if anyone knows of a way of fixing the problems or know of any tools that might work?
The exactly files information by RealMedia Editor:
Stream 0: Audio: bitrate=44100, preroll=1857, sampling rate=44100, codec='44 kbps Stereo Music - RA8'
Stream 1: Video: bitrate=403836, preroll=4824, frame rate=24, codec='RV40'
Many Thanks!
