I just converted a Divx AVI to MPG.....It added 177MB total...Can I shring this down enough to squeeze on a disk?? I love VCDs but can you make them w/out using 2 disks all the time???
VCD is 74 min video on a 74 min CD or near 80min video on a 80 min CD...The only way to fit more is to use x(s)vcd, lower the video and audio bitrate, check some of the tmpgenc templates under tools for how to create those. But remeber that xvcds may not work on you dvd player.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
keeping the video stream VCD compliant but reducing the audio bitrate on the audio stream down to 96kbps or even 64kbps should shrink the file by +100mb.
i wonder, does VCD compliant mean it won't play a VCD with a 64kbps audio stream, even if the audio stream is compliant?
i tend to think even the most finicky VCD/MPEG-1 decoder chips (in Toshiba standalones, for example) will allow a reduced bitrate in the audio stream.
Needing a new camera under $700
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 7th Sep 2009, 15:11 -
needing codecs?
By 2mmy in forum Software PlayingReplies: 3Last Post: 22nd Mar 2008, 12:27 -
Needing a Video Editor for PC
By designbuyers in forum Newbie / General discussionsReplies: 14Last Post: 20th Feb 2008, 03:07 -
needing help with HD movies
By mahfuz in forum Newbie / General discussionsReplies: 0Last Post: 6th Oct 2007, 08:57 -
Needing a new Burner
By Burn it up in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Jul 2007, 23:52
