Hi,
I have an xvid AVI file with a res of 576x320 which I want to resize to 720x480. No problem in VirtualDub, except I can't seem to find a way to resize it without reporocessing it again.
It is already an xvid file and it seems it has to reprocess it again and "convert" it to an xvid file. Is it possible to simply resize the file but in a "direct stream copy" mode that won't involve reprocessing the file but will just resize it ?
Also, as a side note, is 720x480 the best res to convert the original file to in order to make it into a DVD (converting using CCE) or is there a better res that I should convert a 576x320 file to, for DVD purposes, that would give me better quality ?
Many thanks,
Kevin.
The definitive "resize" answer.....
https://www.videohelp.com/forum/userguides/174200.phpSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Want to resize an avi
By janlafata in forum Video ConversionReplies: 2Last Post: 17th Aug 2009, 23:06 -
.avi to DVD + resize
By grandsire02 in forum Video ConversionReplies: 2Last Post: 9th Mar 2009, 17:28 -
resize trouble with avi.net
By g_enqui in forum DVD RippingReplies: 2Last Post: 1st Nov 2008, 14:16 -
Video screen resize question
By Wizard23 in forum ComputerReplies: 3Last Post: 17th Dec 2007, 13:12 -
Resize Suggestion for AVI-DVD Encode
By Soopafresh in forum Video ConversionReplies: 10Last Post: 26th Jun 2007, 11:01
