hi is anyone out there using a pinnacle pctv stereo tuner card ,ive recenly installed mine but am having bad audio sync problems when capturing to hard drive using pctv vision,defragged all other programs shut down etc, even tried using win dvd creator2 with pretty similar results ,contacted pinnacle they recomend capturing to a separate hard drive?any other suggestions folks?
I've got the PCTV Studio Rave package which is probably a bit different. However. I've always found the PCTV Vision program very frustrating which is a common complaint. I never had audio sync problems with it but I've had plenty of others.
I now use VirtualDub to capture video, using the BTWinCap drivers http://btwincap.sourceforge.net/ giving me much better quality out of the card (higher resolutions). Unfortunately, I don't know of a neat way to tune in stations with this set-up which doesn't bother me since I capture from VHS, but might bother you if you're capturing from TV sources. You could connect a VCR to your PC and use the VCR's tuner - that might work. Any suggestions from anyone?
I should point out that the BTWinCap drivers replace the Pinnacle ones and PCTV Vision won't work afterwards. Only use them if necessary, otherwise you could try different versions of PCTV Vision. Try searching the Pinnacle forums for more help. -
I've got a Rave card and got the pro drivers for it, i've seen a great improvment in the performance since updating, i didnt really get it to work properly until i changed the software, with the pro drivers you can capture direct to Mpeg VCD/SVCD/DVD, I use WinVDR Pro for capturing DivX real time using the card, I've tried a few of these cards and found the PCTV the best out of them and only let down by the bugs in the Rave software, The only difference between the Rave and the Pro is the software (Bug Free!!!) a remote that comes with the Pro version and the ability to record direct to Mpeg and of course a price difference, you can buy the drivers from pinnacle or get them off the net there are plenty of sources out there
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 06:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
Win7 and PCTV HD Stick 801e...Can I get HD?
By Throb1231 in forum Media Center PC / MediaCentersReplies: 5Last Post: 15th Nov 2009, 14:18 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41
