When i load an avi/divx/xvid file in TMPGenc express, the size of the video-source is normal(131401 frames, 1hour 27min)but the size of the audio-source from the same file is much bigger(605857479, 3 hour 30min)
I'm having this problem with all my avi-files.
What am i doing wrong???????
You probably have VBR audio.
Open the avi file in virtualdub. If it gives you a warning about VBR auio that is your problem. TmpGenc does not like vbr audio. Use virtualdub to save the audio as an uncompressed wav file then use that as the audio source in TmpGenc.
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 02:09 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 19:48 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
