  1. im about to purchase the nec dual layer burner, but i was wondering if the +dl media will be compatable with my xbox for playing backups of my movies. or any other dvd player, thanks
  2. Member Treebeard's Avatar
    Aug 2002
    The answer is most likely not. compatability w/ dl media is bad and they are way too expensive $13 a disc approx
  3. if you already have a dvd burner.. hold off a bit until the technology gets a bit better as do the blanks.
    blanks are expensive and they don't work in everything, i'd hold off a little while until it catches on more.. that way too you won't end up with a really low DL burner.
    btw. if you don't have a burner at the moment, they it probably wouldn't hurt to get one with the DL feature as I think the prices aren't much more.
