Results 1 to 18 of 18
  1. Hiya
    Im using TMPgenc Author 1.5.20.62
    When loading a file into it as I normally do I am getting the error message
    "A Video Sequence Header is neccessary for every GOP in a standard dvd"
    "The Video Sequence header is incorrect"
    Details of the file(s) I am trying to author are :-
    bitrate 1150000
    framerate 29.970
    Size 352 * 240
    Aspect ratio 12 = -0.0000
    I have searched the forum with no luck so apologise if I have missed a topic covering this issue. I have seen in one post Restream is recommended to solve the problem but I donot know how to do this
    thanks in Advance
    AJ
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    The specs you gave are that of a vcd. That could be your problem. I would assume tmpgenc dvd author would upcode them for you but I don't know. You could convert them to dvd format (720x480, 48khz audio, mpeg2) and try it then.
    Kevin
  3. Thanks for the quick reply, the file(s) are in .dat format and are a vcd, but I want to author them to Audio/Video folders with .vob's and burn them to 1 dvd. I have done this many times before with the same sort of specs just never had this error before. Any more help greatly appreciated
    AJ
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I don't know if tmpgenc dvd author reads .dat files. You could use isobuster and strip the mpg out if it. Then Tmpgenc may read the vcd mpg file better. Give it a try.
    Kevin
  5. They have already been isobusted !! and what you get left is a
    AVSEQ01.dat
    ---------2.dat
    Which I normally load into tmpgenc add chapters then output to audio/video folders.
    Thanks again
    AJ
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Well, I'm running out of suggestions. Here's a few.
    Rename the .dat file to .mpg and try it.
    Is the original vcd intact, try to rerip it.
    Work on converting the .dat to .mpg and strip the .m1v and audio out of it. Then load the seperate files into tmpgenc.
    That's about all I've got left to give. I hope you find something that works.
    Kevin
  7. Originally Posted by yoda313
    Hello,
    Rename the .dat file to .mpg and try it. << Tried No Luck
    Work on converting the .dat to .mpg and strip the .m1v and audio out of it. Then load the seperate files into tmpgenc. (Dont know how to do this !!)
    Kevin
    Thanks for you help Kev
    Anyone else have any idea's ?
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Here's a guide for isobuster from baldrick. It says to save the file as "something".mpg. Maybe you forgot to do this?
    https://www.videohelp.com/forum/userguides/141726.php#vcd
    Hope this helps.
    Kevin
    P.S. Sorry if you've used Isobuster a lot its just forgetting the little things can make a big difference. I also don't mean to insult your intelligence if you've tried this and it didn't work. I'm just trying to give you as many options as possible.
    Kevin
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can add- rewrite the seq. headers with restream or use tmpgenc mpeg tools
  10. Originally Posted by yoda313
    Hello,
    Hope this helps.
    Kevin
    Kevin
    Nah wasnt taken in the way of insulting my intelligence !! You have been very helpful, for a tie-over i've burnt them to 2 x vcd's and they work fine but will still pursue this fault as it is getting to me !
    Thanks again
    AJ
  11. Originally Posted by BJ_M
    I have installed restream can you explain how to do this ?
    AJ
  12. Member adam's Avatar
    Sep 2000
    I don't know how to do it with restream, I only see the option to strip sequence headers, but you can add sequence headers easily with mpeg sequence maker.
  13. Member LisaB's Avatar
    The absolute easiest way to do this is with TMPGEnc, you can even use the free version.
    1. launch TMPGEnc
    2. do file --> MPEG Tools
    3. select "Merge and Cut" tab
    4. click "Add" to add your mpeg/dat file
    5. click "Browse" to specify the output filename
    6. click "Run"
    It will process the file in just a minute or two.
  14. Video Restorer lordsmurf's Avatar
    That's what I was going to say.
  15. Член BJ_M's Avatar
    Jul 2002
    Canada
    both restream and pulldown.exe writes new headers when processing a file
  16. Originally Posted by adam
    I think this has worked, cheers all
    ////AJ
  17. Member LisaB's Avatar
    Mpeg Sequence Maker is an unfinished beta. Moreover, it appears to only accept elementary streams (not mpg). Finally, it doesn't appear to handle MPEG-2 at all.
    Pulldown will handle only MPEG-2. Further, both restream and pulldown only take elementary streams. And although they probably rewrite headers...do they actually insert new headers where none existed before? This would be an interesting test.
    If you want something you can simply drop your MPG into, and have if fixed for authoring with TMPGEnc DVD Author, then TMPGEnc MPEG Tools is the only option I know of....
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    though i am not sure -- i wonder if the smart rendering feature of main concept may work also ...
    if you match the attributes of the source file in main concept - it will do a "smart render" , which is extremely fast and not really a full render ..
    like i said i don't know if it will work , also maybe you can use shrink or something like it to do the same thing ...
    in all cases you really have to use the elementary streams i think ..
