  1. About a year ago I downloaded TMPGEnc to create VCDs. Recently I purchased a burner for my PC along with Easy Media Creator. The software does a terrible transcoding. There is alot of macro-blocking and other problems. Because my trial time has run out on TMPGEnc I cant try the MPEG-2 features to see if it is any better then the crap roxio produces. Is there a way that I could get another 30 days out of it? If not can someone please suggest an alternative.
    This plan is so bad, it must be one of ours.
  2. Member Treebeard's Avatar
    Aug 2002
    the result will be better than the roxio encoder, and its only $50 (i think) for tmpgenc plus.
  3. Banned
    Jan 2004
    Going in Circles
    Buy the program.
    Oct 2002
    It will not be wasted money. Tmpgenc plus does a great job
  5. I think I will just buy it. I have given up on roxio.
  6. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    A good choice.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
