If I want to burn a DVD using Nero 6.3 I select DVD-Video & Select new. This burns a DVD which auto runs when I put it into my Yamada 6100. If I burn DIVX .avi files then I use DVD-ROM(ISO) which enables selection of any of the DIVX files by means of the 6100 built in Menu. However, in Nero If I select "create a DVD" & Copy a new directory of DIVX files to the compilation, (Which it lets me do!),then they are all readable on my PC, ie. I can watch the DVD or select the Divx files by double clicking on them. If I put the DVD into my Yamada 6100 then the DVD autoplays & I am unable to select any of the files in the DIVX folder. Is there another way to create a mixed CD so that all files are available when using my 6100?
The Yamada 6100 can read / decode DIVX & Xvid Format!
You have an extremely unusual situation -- the player is likely programmed to check for DVD-Video content first, and then start playing it if it exists -- it likely never gets to the part where it finds DIVX files.
The answer is probably no, you can't do anything about it.
I take it the Divx files are different from the DVD-Video content? Could you just encode and author the divx content to DVD -Video? -
Originally Posted by mattiusbWant my help? Ask here! (not via PM!)
No I meant that it defeats the point of having DIVX capability if you re-encode the DIVX files to MPEG2 DVD, NOT that it defeats the capability of playing DIVX files!
Looking for free DVD video editor that will create chapters & titles
By Brent G. in forum EditingReplies: 1Last Post: 22nd Feb 2009, 02:25 -
I want to create video & photos on a DVD and play it on a DVD player
By samoyed in forum Authoring (DVD)Replies: 8Last Post: 14th Jan 2009, 00:27 -
What program to use to Create a DVD & Menu from FCP.
By DigitalGuard in forum MacReplies: 2Last Post: 1st Jul 2007, 16:29
