    Oct 2003
    IL [USA]
    I have two DivX files that I encoded from a single, large .avi video. I was running into problems with VirtualDub when I tried to encode the entire thing to a single DivX file. About 80% through, VirtualDub would give me an "out-of-bounds memory access (access violation)" and the encoding would stop. I did some searching through the forum and saw a post that recommended encoding up to a frame somewhere before the error occurred, and then encoding from the following frame to the end.
    So now I have two DivX files that I need to join together. Is there an easy way to do this using VirtualDub (without having to re-encode the two files together), or is there another program I should use for this?
    Apr 2002
    The State of Frustration
    I would use AviSynth:
    AVISource("G:\brandx.avi").Trim(0,110109)+AVISource("G:\brandx.avi").Trim(120000,305000)
    Provided the corrupted portion of the original video is frames 110110-119999.
    Hello.
    Oct 2003
    IL [USA]
    Am I to use the original .avi file with that program, or am I to use the two DivX files I encoded from it?
