    Jun 2004
    Toronto, Canada
    1. I have a home made movie on DVD-R, is there any software to write protect it??
    2. Which style is better to re-encode using TMPGEnc Interlace or Progressive??
    3. When using TMPGEncPlus how to you change the framerate from 480x480 to 352x480 or 720x480 but still re-encode under NTSC film 23.976 format. The fields are frozen and I can't change the numbers. Or is it better to re-encode at 29.97 NTSC.
    Jun 2004
    Toronto, Canada
    CAN ANYONE REPLY
  3. This area is for discussion/questions about the program SVCD2DVD. Your questions need to be addressed to the appropriate forum areas.
    One bit of advice though: question #1 will get you laughed at and royally flamed. Ask it at your own risk.
    Jun 2004
    Toronto, Canada
    If this is a forum, people are looking for help, they should not be worried about the questions they ask.
    A simple answer is fine. If this is in the wrong section you did not direct me to the right section to post my thread.
    Thank for all the help! You were Great
    I agree, but a search for "copy protect burned DVD" or something similar will tell you why I answered the way I did.
    Sorry, I thought it would be clear when you looked through the forum headings. Try "Newbie Conversion" or "Advanced Conversion", preferably after looking through some of the guides listed under "How To" at left.
