Here are my 2 cents......get a motherboard the will give you options..like serials for products like SATA HD. plenty of PCI ( I would not wait for the pci express ) it will take some time to perfect and might be too expensive.Enough USB2 and Firewire ( I personally use all my connections , I use external devices like DV, HD, DVD, Video Cards. ) know your memory and your FSB limits , before purchasing. As far as CPU get the fastest you can afford keeping in mind that a motherboard and a cpu is not a complete computer. Whatever you chose get a lot of airflow to keep your investment cool. and also consider enough power to anythings you are going to power with this computer. well I hope I made this general enough to just keep this in mind so you to decidewhat you want and are going to make you feel good about your puchase. .
. another thing once you do decide go to their forums and look for pros/ cons and conflicts with other media .....
Results 31 to 34 of 34
I'd go with Intel P4 if you plan to use it for video and audio editing. Intel's tend to fair better at video and audio editing because of its raw clock speed. If you go Intel go for a Northwood core, not the newer Prescott core. The newer Prescott core releases more heat and craves more power and performs worse than the Northwood core in most programs. On the upside the Prescott does have SSE3, but no relevent programs use it right now.
If you go AMD, go with a 64 bit version. It should fit your budget and considering Windows 64 should be comming out soon(2005 last time I checked, but hey its Microsoft so who know).
Intel has taken the trophy for being king of heat with their newest flagship core, Prescott 3.2E. It idles at about 50C and can shoots to 65-70 under load. No AMD processor produces that much heat. Intels previous core, Northwood, was about 56C under load.Also, keep in mind that AMD CPU's tend to run very hot (even at idle). The packaged fan should be upgraded at the time of installation. -
May as well buy now unless you're waiting for something specific. If you want a really good multi-display card I think the Parhelia is still the best around for the cash. Otherwise you're looking at Fires and Quadros which can get pricey, especially for dual-link DVI monitors (not to be confused with dual DVI). A lot of the higher end gaming cards have single DVI still and for whatever reason aren't true dual- or triple-head cards. Apparently the Parhelia isn't so bad at gaming, but it isn't DX9 native.
If you want a good all-around multimedia/gaming card with dual monitor support you might want to look at the ATI All-in-Wonder 9600XT.
http://www.ati.com/products/radeon9600/aiw9600xt/index.html
As low as $189 at Newegg.
http://www.newegg.com/app/viewproductdesc.asp?DEPA=0&description=14-102-352&ATT=Video+...C-pr1c3grabb3rNothing can stop me now, 'cause I don't care anymore.
Just built my computer..any tips?
By NaHLiJ in forum ComputerReplies: 25Last Post: 25th Oct 2011, 11:54 -
Have a new computer built to run CS 5?/ Help!!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2010, 20:58 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 16:19 -
Has Anyone Built an I5 Processor Computer?
By Soopafresh in forum ComputerReplies: 4Last Post: 5th Dec 2009, 16:46 -
DVD plays on Computer but not built in TV DVD player
By crawlfish in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2008, 08:35
