  1. Hi!
    I use sony handycam capture on factory video. Then go to TMPEGnc convert to mpeg-2 for 30 sec as test. I setting from 1900 to 2500 vib.rate. Been run on all setting all same problem. But when start play it blank . I press pause then press play it show motion and picture look great. Been run about 10 second it become grassy motion then disappear.
    Any suggest best setting for right playback on edvd player?
    Will svcd playable most all dvd player??
    For vcd I setting work perfect all way not like svcd but I like svcd for picture cool.
    Jul 2001
    Brazil
    Are you sure that your DVD Player Unit plays SVCD? If you don't know, go to http://www.vcdhelper.com/dvdplayers.php and verify.In this site you"ll may see include other compatibilities brands. I know that VCD 2.0 is playable all most DVD Player Units.
    I believe that's all for the moment and the first step. OK?
    After this, please back the question.
    Jul 2001
    Brazil
  4. Hi Hey thank guy I found my brand dvd player not support svcd. That why I understnad Many thanks . So I use vcd more.
