Is it me or is this website down?
Need region free formware hack for lg 4082b if anyone can help, thanks.
Results 1 to 11 of 11
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
did not work for me, could it be I have some sort of software which is stopping me?, ad blocker etc etc.
thanksPAL/NTSC problem solver.
I have a ad-blocker on and it works fine.
What is it saying when you try to go to the site? -
usual internet explorer website not found page, thanks for trying to help me.
I found a diffrent link, try this one.
http://www.firmware.fr.st/ -
did you get it to work, coz I didn't!
Gateway Timeout
The following error occurred:
[code=DNS_TIMEOUT] A DNS lookup error occurred because the request timed out during the lookup.
Please contact the administrator.PAL/NTSC problem solver.
It's working for me.Have you ever had any trouble before going
to the website.
What internet are you using? and are you using Internet Explorer? -
never got their website to work, yes using ie6 updated
I don't know what going on.
Give me the name of your dvd writer. Maybe I could look for a
link for you.
You can try region free software found here.
https://www.videohelp.com/tools?s=25#25 -
I am using Power Producer Gold, which I am finding is great when it works, great result rather than capturing to avi, then tmpgenc to mpeg2 etc etc.
I was trying to make sure that nothing I had loaded was causing PP to crash, getting the following message:-
appNameroducer.exe
pdcmpg2v.dll
modver 4.0.0.1008 offset.00018app
the cyberlink techie told me the following:-
to ensure MS Messanger was disabled and then do the following:-
(a) Start --> Programs --> Cyberlink Power Producer (uninstall it)
(b) Start --> Run (keyin "regedit") --> HKEY_Current_User --> Software --> Cyberlink --> Power Producer --> delete the folder.
(c) Start --> Run (keyin "regedit") --> HKEY_Local_Machine --> Software --> Cyberlink --> Power Producer -> delete the folder.
(d) Re-install Power Producer
But, I was wondering if DVD region killer that I was using was a problem with PP, thats why I was trying the firmware route, sorry such a long story.
My Burner is LG 4082B and am using LG firmware 2.06, also whats the best burnign software, did use the one with TMPg author fine, but someone said it was flaky, tried Nero and seems fine, noyl thing about Nero is , it takes too much control of your computer.
Thanks for all your help, I am currently following the Cyberlink techies advice, as above and reinstalling PP Gold, see where it gets me.PAL/NTSC problem solver.
Use My ip camera in my website
By AMZ in forum Video ConversionReplies: 17Last Post: 16th May 2015, 16:42 -
This website
By Will Hay in forum Off topicReplies: 24Last Post: 17th May 2013, 17:11 -
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 6th Sep 2012, 23:42 -
Website builders?
By Hank Kinsley in forum ComputerReplies: 4Last Post: 20th Feb 2009, 08:29 -
HOw do you creat e-com website?
By snickdog in forum Off topicReplies: 5Last Post: 3rd Dec 2007, 20:33
