    Aug 2001
    Vδsterεs, Sweden
    Well something is utterly wrong.
    When i try to view my SVCD the timer on my standalone start ticking mut no picture nor sound. (player is a Hitachi 515E)
    So i get Irritated and start cursing about the player and the seller that theyr bouth shit..
    What if i try to play it on my computer then?
    Heres the interesting part..: My comp cant find the disc, it just tells me there is no disk in the drive!
    (disc drives are a Sony cd r/rw-burner and a pioneer DVD)
    Someware something have gone very bad. Any ideas and help wanted, im tearing my hair here..
    the MPEG is coded from a Div-x avi with TMPGEnc 2.00.29, muxed in BBmpeg 1.24.
    -so far viewable
    then I use TSCV 0.72 rel 8 and VCDimager 0.7.11 to get the cue/bin and burn it with cdrwin.
    i run Win2k on a 750 athlon with 384MB RAM, 80GB HD.
    oh yea i burn them on memorex cds.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  2. did you use a keygen'ed serial for cdrwin?
    if not, maybe you could try some other burning app (except for nero), like blindwrite or fireburner, or even cdrdao for burning the bin/cue image...?
  3. Did you finalise the cd? If not, use cdrwin's option to close the session.
  4. Had the same problem used fireburner TOA and close disk - solved the problem
