hi,
i am setting up a new home theater for our new house and neew a new DVD player. i already have a toshiba 51H84 51" tv and will be getting a Harman/Kardon AVR 330 receiver, shortly. can someone recommend a nice DVD player that will work well with these other components. it should have digital audio out too,
thanks!
Go into the dvd player section on the left and select all the features you want, then do a search and it will display all the players that have those features, then find whichever one is in your price range.
As for the digital audio out, I don't think i've ever seen a dvd player without a digital audio out, the only trhing you need to look out for is if it has coaxial vs. optical output. -
The most popular upscaling DVD player with DVI, although it will upscale in its component output too is the Zenith DVB318. Just check out the thread at avsforum.com - dvd player section, they're raving about it esp. for the price. I think you can get it for $160 here.
http://www.gochnauers.com/tv_vcr/tvvcr.html#dvd
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
