  1. Been using dvd decryptor for ages to rip movie only to HDD
    but this has been bugging me so i have to ask
    In file mode under edit there is the option select main movie files (which i always select) but there is also the option select main movie files +IFO,s
    what is the extra IFO,s for\or what benifit would i get by using it instead of just main movie files..
    canada
    That option is to select only the main vobs plus all the ifos and the other is just the main vobs and the ifo for it,thats just if you are going to reauthor a movie or just need those files,otherwise choose the normal file mode so all the files are extracted.
  3. So you only need all the IFO,s if you are going to reauthor
    canada
    Depends on the program you are using.
