I have a movie (.Mov) that I am trying to burn in DVD format and it is getting like a nightmare.
Problem is as follows;
When I play the movie with QT I get a nice good screenfilling picture. According to QT the movie is 720 * 304.
Then I start FFmpegX 0.9L select there thru "Quick Presets" DVD and I end up (after a full day!) with a DVD. However when I burn that DVD all I get is a rather small, certainly not screenfilling. picture.
Help would be very much appreciated.
Below I have pasted beginning and end of the process Information:
Encoding started on Sun Jul 11 01:16:28 CEST 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 276807!
INFO: [mpeg2enc] Guesstimated final muxed size = 4148720021
Input #0, wav, from '/Users/tonio/Desktop/LAST_SAMURAI MainFeat/HB.LastSamurai_Titels.mov.wav':
Duration: 02:33:55.7, bitrate: 1411 kb/s
Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
Output #0, ac3, to '/Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.ac3':
Stream #0.0: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 105kB time=1.9 bitrate= 448.0kbits/s
size= 247kB time=4.5 bitrate= 448.0kbits/s
size= 406kB time=7.4 bitrate= 448.0kbits/s
size= 504922kB time=9232.9 bitrate= 448.0kbits/s
size= 505074kB time=9235.6 bitrate= 448.0kbits/s
size= 505083kB time=9235.8 bitrate= 448.0kbits/s
video:0kB audio:505083kB global headers:0kB muxing overhead 0.000000%
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.ac3 looks like an AC3 Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 4000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: AC3 Audio stream 00 (/Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.ac3)
INFO: [mplex] AC3 frame size = 1792
INFO: [mplex] AC3 AUDIO STREAM:
INFO: [mplex] Bit rate : 57344 bytes/sec (448 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4526848
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio bd: buf= 16384 frame=000000 sector=00000000
++ WARN: [mplex] Discarding incomplete final frame AC3 stream 0!
INFO: [mplex] Scanned to end AU 276806
INFO: [mplex] STREAM bd completed @ frame 288617.
INFO: [mplex] STREAM e0 completed @ frame 276806.
INFO: [mplex] Multiplex completion at SCR=831217664.
INFO: [mplex] Video e0: buf= 4243 frame=276806 sector=02058164
INFO: [mplex] Audio bd: buf= 5632 frame=288617 sector=00256550
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 4148720021 bytes
INFO: [mplex] Sequence headers: 18711
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 276806
INFO: [mplex] No. Groups : 18711
INFO: [mplex] No. I Frames : 18711 avg. size 25296 bytes
INFO: [mplex] No. P Frames : 73876 avg. size 17285 bytes
INFO: [mplex] No. B Frames : 184220 avg. size 13019 bytes
INFO: [mplex] Average bit-rate : 3593200 bits/sec
INFO: [mplex] Peak bit-rate : 4260800 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: bd
INFO: [mplex] Audio stream length 517203461 bytes.
INFO: [mplex] Syncwords : 288619
INFO: [mplex] Frames : 288619 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 35 Buf max 1603
INFO: [mplex] MUX STATUS: no under-runs detected.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.mpg...
STAT: VOBU 16 at 3MB, 1 PGCS, 0:00:07
STAT: VOBU 32 at 7MB, 1 PGCS, 0:00:15
STAT: VOBU 48 at 10MB, 1 PGCS, 0:00:23
STAT: VOBU 18704 at 4555MB, 1 PGCS, 2:33:52
STAT: VOBU 18711 at 4557MB, 1 PGCS, 2:33:56
INFO: Generating VTS with the following video attributes:
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: ac3/6ch, drc
STAT: fixing VOBU at 3MB (17/18711, 0%)
STAT: fixing VOBU at 7MB (33/18711, 0%)
STAT: fixing VOBU at 10MB (49/18711, 0%)
STAT: fixing VOBU at 4555MB (18705/18711, 99%)
STAT: fixed 18711 VOBUS
INFO: dvdauthor creating table of contents
scanning /Users/tonio/Desktop/LAST_SAMURAI MainFeat/movie.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
/Applications/FilmBewerking/ffmpeg/ffmpegX.app//Contents/Resources/mkisofs: No such file or directory. Invalid node - /Users/tonio/Desktop/LAST_SAMURAI\ MainFeat/movie.mpg.DVD
