well all use is the divx 5.1.1,and the xvid 1.01.
never had a problem with picture,sound or syncing issues.
dont see the need of all the other ones.
by the way,my divx,xvid,mpegs,etc will all play now in windows media player,power dvd,etc with no probs either,no upside down vids etc.
i also installed the ac3filter,and thats helped a few times in virtualdubmod for keeping 5.1 audio on xvids. -
The last time I bothered to mess with it I remember there were times when VirtualDub couldn't open divx low or fast motion with only divx 5 installed and if I installed all of them there were 2 common problems that would show up in TMPGEnc, either it would want to do an inverse telecine on files that were already 23.976fps or it would think the audio file was much longer than it actually was and predict some ridiculous file size for the finished product.
for problems like that,i noticed that if i selected mp2 constant audio,it would be fine,but any setting involving variable rate audio would predict file sizes up to 5gig+ and byond,and that was on tv episodes roughly 20 minutes long.
even then,if you get a movie your converting and its 2 mpegs,or 2divx,xvid files,then you need to reduce them to about half of a dvd in size so the whole movie would fit on 1 dvd-+r.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25 -
3ivX to XviD problems...
By GangstaRap in forum Video ConversionReplies: 8Last Post: 6th May 2007, 11:25
