Out of the blue my 2500 (1.07 firmware) is only showing up as 2x in every application (Nero, Roxio).
I have tried to remove/reinstall the device in windows without any luck.
Any hints?
Check to make sure DMA is enabled (may require removing your IDE controller and letting them re-detect in XP). Also, if you have media in the drive, apps may show that as your max record speed.
Nothing can stop me now, 'cause I don't care anymore. -
Yep. DMA is ok. Media is BulkPaq Generation 4 4x.
Tho, when inserting a DVD+RW it states 2.4x.
Might be the media after all.. But i have been using this for yonkers and never seen a problem. Will pick up a disc of a different brand tomorrow.
Thanka for the tip tho. -
What is the MID code for those Bulkpaq discs that you had in your drive when you were checking allowable burn speeds?
WesleyTech.com - Blu-ray Disc & consumer technology news, reviews & articles
anyone know how to unlock denon dvd-2500 regions
By similar in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 15:03 -
I just bought an expensive laptop - was it a $2500 mistake?
By Eat Right in forum ComputerReplies: 35Last Post: 18th Nov 2009, 13:33 -
Sudden restart
By alintatoc in forum ComputerReplies: 12Last Post: 25th Mar 2009, 11:49 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 12:34 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 11:23
