I'm having trouble getting good results shrinking Stargate DVDs (series 3 PAL) with DVD2One - quite a lot of background (and even foreground) pixelation on flat colours etc. in some (not all) episodes with variable. Have people had better luck with constant?
Cheers,
B
Use DVD Shrink with Deep Analysis for SG1. Just trust me on this one.
Constant is almost always a better option. Variable saves time, but results in mucho artifacto.
Droplets of yes and no in an ocean of maybe. -
Constant is _supposed_ to be better for long movies (2.5+hrs) but some people (myself included) find that it produces odd colour artefacts sometimes (pink or green flashes between scenes). I always use variable now.
When I backup Deep Space Nine DVDs (3hrs each) I find both constant and variable modes give slight artefacting on flat backgrounds (walls usually) and smoky scenes, but variable has less glitches as mentioned above and is a better copy overall.
There's a thread http://www.dvd2one.com/forum/viewtopic.php?t=193 which explains what each mode is supposed to do, and has some reports of problems with constant mode.
StarGate SG-1 question
By zzyzzx in forum Off topicReplies: 38Last Post: 14th Jan 2012, 17:11 -
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 07:49 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 17th Oct 2007, 23:56
