Hi
I've been using SCVD2DVD for a few weeks now.. straight as it was all out of the box settings.. However now it's beginning to freeze on TS Editing stages.. even left it six hours and it was in the same place![]()
I have uninstalled and reinstalled the software.. same probelm exsists. Could someone post up the DEFAULT settings for the splash screen and options? This will allow me to check that mne have not been played with!
A very desperate Mipple!![]()
CAn you post your log?
Ok here's a few screenshots.. I will up the log in a little while as I'm trying it again:
Main Screen:
Options screen
How do I return this to default? When I choose the non-dvd folders I don't get the chapters options./... which I've always had..
getting confused now
Will up the log shortly... all help appreciated!
Ok log..... This is where it sticks for HOURS|!
Starting SVCD2DVD: v1.51.2.0
Begin time: 21:29:44
******** Ripping BIN images to get mpegs (VCDGear -fix)
(Total size: 1610MB, Duration: 00:03:02, Rate(MB/Min): 530.09)
Analysing File: F:\•·.·´¯`·.·• Newsgroup Download •·.·´¯`·.·•\alt.binaries.pens_pencils\flix_ctdq.cd 1\flix_ctdq.cd1.mpg
Analysing File: F:\•·.·´¯`·.·• Newsgroup Download •·.·´¯`·.·•\alt.binaries.pens_pencils\flix_ctdq.cd 1\flix_ctdq.cd2.mpg
-->Processing 2 mpeg files
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
(Total size: 794MB, Duration: 00:03:21, Rate(MB/Min): 236.10)
******** Resampling audio from 44.1 KHz to 48 KHz
Skipping....
******** Trimming start of video ES
..Never used to it used to take 36 mins
I'm just guessing but maybe its the funny path:
•·.·´¯`·.·• Newsgroup Download •·.·´¯`·.·•]#
try moving your sources to f:\downloads.........SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for your reply ChrissyBoy....
I will take it out of there and have another stab... see if that works
Sometimes it's the most obvious of things eh?!
Mips
VCR Freezing
By koberulz in forum Capturing and VCRReplies: 9Last Post: 24th Feb 2012, 23:40 -
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 15:52 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 29th Dec 2008, 00:26 -
ffmpegX is freezing! Help!
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 13:41 -
Why are my movies freezing?
By bigmatt72401 in forum DVD RippingReplies: 10Last Post: 6th Aug 2007, 06:41
