Been looking all over the net for a solution to this one.
I'm trying to burn AVI file which has 5 channel audio to DVD and maintain the 5.1 audio.
Currently using Nero but it will only let me burn with stereo.
other posts suggest that i seperate the audio stream and add it later. using virtual dub.
Being lazy just want the easiest software to do it.
any help would be greatly appreciated
try winavi video converter, it claims that it can keep the ac3 5.1.
or use this method
https://www.videohelp.com/guides.php?guideid=447&howtoselect=4;10#447 -
Thanks Baldrick,
not sure how i missed it before. But giving it a try.
Nice guide by the way, really really really useful!!! -
You can do that with Ulead DVD Workshop as long as the audio is DVD compliant. When you get to the burn menu select "do not convert compliant files". Not sure but I think most Ulead DVD software has the same option.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
each audio track on different audio channel or device
By mikedepetris in forum Software PlayingReplies: 2Last Post: 28th Nov 2009, 09:56 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47
