I got some xvid and divx files and I want to burn them to a DVD. Im using Ulead MovieFactory 3. So I load them up in UMF3 and it says the files are too big to burn. I know you can convert MPEG-2 audio to DVD audio with TMPEG and it lowers the size considerably, but is there a way to do that with a divx and xivd file? I tried converting one of the files to svcd last night, but after about 8-12 hours, only 43 minutes were converted, and I dont even think the sound was converted either. I dont want to convert it to VCD cause its gonna lose alot of quality points. So can I convert the audio only so the file size isnt so huge? Thanks.
always convert the audio to wav and use it as source if you are using tmpgenc and divx/xvid sources. you can convert the audio directly to mp2 or ac3 with ffmpeggui or convert to wav with virtualdub.
I found I don't have any a/v sync issues once I'd set up TMPgenc to use SCMpx encoder ( http://www.din.or.jp/~ch3/index_e.html ) to do the audio conversion. It creates a temp wav automatically before encoding, it's very fast and the quality is very good too.
use winAVI,i can convert and burn a 2 hour xvid or divx file in less than 1 hour.
no shit either,just a couple of options when you start,like PAL or NTSC,frame rate,and where its going to be saved,and thats it.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
DivX/Xvid/Whatever to DVD
By FallenAngelII in forum Authoring (DVD)Replies: 4Last Post: 12th Dec 2007, 18:04 -
DVD vs XviD vs DivX ?
By richbell in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2007, 07:17
