When i encoded Forrest Gump to fit 1 cd using SBC, the quality was not that good. I tried re-adjusting the video bitrate of the encoded Divx to a higher one hoping that the marcroblocks would go away in fast-motion scences but that didnt happen. I tried encoding the whole dvd again this time with with a higher bitrate and the quality was perfect. My question is:
Are Divx similar to mp3's where u can change the quality of mp3 file by changing the bitrate?....It seems that i cant change the quality of the Divx after it has been encoded with a specific video bitrate.
Help Please.
thnx
Don't forget ,Forrest Gumb is almost 3 hour movie so would be very wise if you will apply more bitrate for better quality
Many people claim to be able to improve perceived quality by adding filters (in TMPGENC or Virtualdub) which have no direct effect on filesize or bitrate.
In my experience the only way to get a substantial improvement in quality is to crank up the bitrate.
Either way you'll have to re-encode. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
It isn't just a claim, it's fundamental to how MPEG and similar algorithms work.
MPEG basically encodes edge information - I-frames care about edges in the spatial axes (so salt and pepper noise is a killer), while P/B frames care more about edges on the temporal axes (ie. caused by moving objects). The more edges there are the more bits you need to encode them for a given quality, and if these edges derive from noise then most of that effort is wasted.
Careful spatial (smoothing) and temporal filtering can reduce the edginess and noise in the source, allowing MPEG to use all its bandwidth on important information.
If you look at a commercial quality VCD you can easily see that a light spatial filter (at least) has been applied.
I completely agree mpack, I find spatial filters (especially when encoding from a capture source) are a big help to the mpeg algorithm.
The forums are however full of arguments as to which processes provide the best quality. One persons trash is indeed anothers treasure.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Getting video bitrate
By grv575 in forum Video ConversionReplies: 2Last Post: 5th Jan 2010, 14:35 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Video Bitrate
By HartsVideo in forum Video Streaming DownloadingReplies: 39Last Post: 9th Aug 2009, 03:35 -
Video Bitrate
By Nitro89 in forum Video ConversionReplies: 30Last Post: 11th Feb 2009, 08:04
