Bin it ? (Er... that's trash it to the Americans, nothing to due with BIN's etc).
If you want to put it on a DVD you have to author it, unless your player handles MPEG-2 on a DATA disc, you can't just put it on a disc and play it. This is effectively what your PC's playback software is doing.
Since you don't say otherwise, I will assume you encoded it in the first place and have the necessary codecs on your machine. It might be a matter in TMPGenc of bumping the priorities in the options to make it look at a different import filter (assuming the MPEG-2 isn't a mess).
I think we need more info to help you out here, I for one am not psychic and can't second guess your source.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
