Im trying to figure out dvdlab. i wanna make an intro screen right before the movie starts. Probably use one of the premade backgrounds with some text/date along with the THX sound piece. I have the mp3 version of THX but dvd lab wont accept it since its not in MP2,AC3, or wav. I also have a wav but it wont accept it either. Anyone have any advice or suggestions?
Your wav probably has the wrong frequency. Needs to be 48kHz. dBpowerAMP Music Converter is a simple, fast and free tool that can do the conversion.
is there a tool where i can rip the THX sound right from a DVD? I know Star Wars has that sound so maybe i rip it from there and still maintain the surround sound.
Yes, there are plenty of tools. I use Vobrator.
If you know which VOB it is in, you can even extract it directly from the DVD with DVD Decrypter in IFO mode. -
i downloaded that program but it wont work in either ME or XP. The program loads up but as soon as i select a vob file from the VIDEO_TS folder it errors out and closes.
Yeah, I've seen many people report bugs with Vobrator. Not sure why, it has always worked great for me on my XP. I guess I'm lucky.
Vobedit can also do it and DVD-Lab too. I like Vobrator because it has a preview and can extract only the part you want, no need to demux the whole VOB. See if you can make it work, if not, try the other tools I mentioned.
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 18:45 -
DVDLab Pro Menu Text Disappearing
By C0SM0 in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2009, 17:33 -
DVDlab menu question
By rizay in forum Authoring (DVD)Replies: 3Last Post: 12th Dec 2007, 09:54 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 22:32 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 08:28
