I'm trying to capture from my TV Tuner on my Voodoo 3 3500 to my HDD (uncompressed AVI) I have sucessfully gotten audio in the software that comes with it, but can hear audio in sonic foundry video factory and virtual dub but its not capturing it. It says its capturing it but its never in the saved file. I have already checked my line in and it wasn't muted. Thanks!
What sound card do you have?
The 3500 tuner runs audio via the sound card and typically aux. this must be set to 'on' in the sound card or MS sound applet.
When you watch TV on you PC do you get sound?
The 3500 capture device is VFW (video for windows) and the tuner part is known not to work with a lot of other apps.
Best bet is to capture with the 3500 vcr, which is very good by the way - you can capture AVI mpg1/2 and then load into your other prgm's as files. -
I have a Aureal Vortex 2 SQ2500 and I do get sound when watching my tv tuner. So I know I have my audio cable plugged in from my vid card to audio card.
USB 2.0 Video Audio capture Card
By jj3502 in forum Capturing and VCRReplies: 0Last Post: 3rd Feb 2010, 04:09 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
How do i connect audio on capture card?
By GLE3 in forum AudioReplies: 11Last Post: 9th Mar 2009, 22:06 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 7th Feb 2008, 23:27 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
