I have a Sony TRV22 and it no longer appears to be recognized when I plug it into the firewire. I've tried two different cables as well as uninstalled and reinstalled the 1394 controller in the device manager.
I am using XP home and am very perplexed (as well as frustrated). Any recommendations?
Results 1 to 10 of 10
As I understand it, you don't need any special drivers for the camcorder. The firewire should recognize the camera install it. I thought you only need drivers for USB. Is this not correct?
I have a Samsung DV cam corder and had to dload the camra driver for it . when you plug it in you should see the camra reconised in system properties if not then you will poss need to dl the driver for it. Worth checking out just do a search on the net for your cam
My sony cam was plug and play, different model than yours but I suspect that it would be the same.
Do you have a different computer to try the cam on? How about a different device to try on that port? Might simply be a loose wire if your firewire port is not a pci card type.
Does it show up in "my computer" after you plug it in? If it does and you have two capture devices you have to select your cam as the capture device in the software you are using. and now for the really dumb suggestion.......drum roll please..... Are turning the cam on to VCR mode? -
I am sure my camera was plug and play also. Unfortunately, I don't have another device to test out the hardware. I know this worked a couple of weeks ago. I guess my options are (in order of preference):
- Try out the camera on someone else's PC - but I don't have anyone nearby offhand
- Install a firewire card I have - instead of using the onboard firewire
- Reinstall Windows XP
Any other thoughts? -
Sounds about right to me, have you checked the wire connections for your onboard firewire? I'd reinstall as a last resort probably won't solve anything anyway, find out if the cam works on another compouter first.
1. isntall a new firewire card.
2. maybe is the soft that you use to capture.
3. sony is plug and play.
4. windows xp
5. test the camera into a dif pc, maybe that is the problem....
that's it.... -
After nearly turning my system upside down, I managed to figure out it is the camera after all - swaped cameras with a friend and it was not found on his MAC and his camera popped right up on my PC. And of course it is now been 13 months since I bought it.
Not sure what the repair might run - so - is it feasible to capture video through the USB port or not?
Thanks. -
Originally Posted by heiber
Can I capture with USB 2.0 or does it have to be Firewire?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 7th Feb 2009, 13:19 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 01:22 -
Best Software For Firewire Capture?
By DW in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 2nd Apr 2008, 22:40 -
SA 8300HD Firewire Capture
By nebbish_2112 in forum DVB / IPTVReplies: 0Last Post: 30th Nov 2007, 08:15 -
Best Capture from a firewire .
By ZaYoOoD in forum Capturing and VCRReplies: 6Last Post: 25th Nov 2007, 20:41
