I have seen this question asked before, but I have not found the answer yet, ATI all in wonder radeon, windows 2k, 98se, xp, I get "no capture driver" can anyone help?
I'm having the same problem Athlon, Windows ME ATI AIW 128. I install Virtual dub. Fire it up and get the same message. If you here anything My Email is John817@Adelphia.Net.
Thanks,
Little John -
Did you check out this link?
https://www.videohelp.com/phpBB/viewtopic.php?topic=60704&forum=2
I was having the same problem, tried this stuff in here and now I can use VirtualDub with ATI. And honestly, I would have given up on VCDs if I couldn't get VirtualDub to capture an AVI for me. -
Make sure you have installed DirectX8.0 and the DirectX DV plugin... both from Microsoft.
you need the "Wrapper"
search for previous posts by me on this subject I don't remember the URL right now
it's a WDM Wrapper and it will allow you to capture with VirtualDub and an ATI card -
Thanks for the help, I got the VfW-WDM, it worked, so now I can cap straight to DIVX, instead of MPEG1 with ATI, and then encoding.
ATI TV Wonder 650 PCI - Black Screen in virtualdub
By HidenSeek in forum Capturing and VCRReplies: 50Last Post: 21st Mar 2012, 09:18 -
Ati 600 usb stick and virtualdub capture
By buckethead in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2011, 16:13 -
Diamond ATI Tv Wonder 750 USB and virtualdub
By buckethead in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2010, 03:34 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
