Hello all
Once I used Easy CD Creator 5 Platinum to create vcd and encountered some issues:
Its VCD Creator stores mpeg data in musicXX named files->how to change them to avseqXX?
I have not seen any program worse than this Easy CD.
>It can't burn all of the MPEG to the CD and closes the CD before burning the Video file completely.
When playing back the vcd I found that the video dat file is incomplete(some of the video from the end of it is omitted and this is more than 10 minutes)( I wonder why and how the file is splitted>the burned vcd is shorter than the source mpeg file)
It can't read the CD-R size(650or700)so the app complains and warns about the file size that is below 74/80 minutes(CD-R capacity).I even made an image file and then noticed that it can't open the image.
All of this forced me not to use this program more than one time.
Now I'd like to know if anyone's had similar problems with easy cd creator.
I need some help to find out that if the program itself causes these problems (or the reason is somewhere else)?!
<font size=-1>[ This Message was edited by: Pied-Piper on 2001-11-15 23:16:26 ]</font>
