When i capture DV-AVI from my sony HC30 the kbps is 1785.72 when i edited the video with power director it comes out at 2132.11 then when i use uleads workshop 2 to add a menue and then burn it to dvd at best quality it converts it to 8000 kbps.
If i started out at 1785 kbps why do i end up with 8000 kbps. Didn't ulead incress the kbps even more?![]()
I just want the best quality video i can get i don't care about the sound.
aren't you mixing kbps with kbytes?
1 kbyte = 8 kbit. -
I don't know? Thats the info workshop 2 gives me. Any other tools that will show it?
Heres a picture of it if it works.
http://www.geocities.com/david9723/kbps.jpg
It says data rate 2132.11 kbps not bytes.
DTS 15xx kbps to DTS 768 kbps and tsMuxeR question.
By Jared_ in forum AudioReplies: 0Last Post: 1st Jun 2009, 10:46 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57 -
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 13:14 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 01:35
