hi![]()
got a movie in svcd in two parts, is there a prog that u can bring both parts in and remove the overlap to keep a continues stream, no jumps etc. also what do u use to convert the file to burn onto dvd?
many thanks![]()
There are a lot of methods, but if you want an easy way, in my opinion, use SVCD2DVDMPG. You will also need Isobuster, and an authoring program, such as TMPGEnc DVD Author. TDA is payware, but the others are free. You will also need .NET from Microsoft. I use this version 'dotnetredist.exe' Version 1.0 as the newer versions seem to add in a password requirement to your system.
hi
does any of these progs allow u to join and edit or are these just for convertion etc?
many thanks for the info
The SVCD's that I have were created with DVD2SVCD and they have several seconds overlap. I just left it there, not very noticable. I believe you can use the 'Source range' selection in TMPGEnc DVD Author to edit this out when you author. TDA lets you run one part of the file after the other seamlessly and they will play back that way. You can get 2-3 SVCDs onto a DVD easily. I would rather 'join' them in TDA to simplify things and lessen the chance of audio sync loss.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
