Hello
I have a problem and I hope someone could help me.
I have two XviD avi files and want to merge them to one. For these two avis I have also two subtitles and logically I also want to merge them to one. After that I want to create a DVD with selectable subtitles.
How could I do this? Which program(s) do I need?
For the subtitles, use Subtitle Workshop or something similar to merge the files. Here are all the tools:
https://www.videohelp.com/tools?s=24#24
For merging the video, you could try something like FileMerger, or the following:
- Open the first section in VirtualDub
- Select "Append AVI Segment" from File
- Open your second file
- Select "Direct Stream Copy" in both Audio and Video menus
- Go to File --> Save as AVI
That should output both files as one.
I don't know what authoring tool you are using, so I can't tell you how to make your selectable subtitles. You should be able to find a guide for it yourself.
Best of luck,
Cobra -
small question
when merging 2 subtitle files to 1
there is one problem
and thats the time when the line is shown is double
i mean the time from subtitle file 1 is still there
but so is the time from subtitle file 2
something like that cant just be changed
unless you do it manual
Question about Blu Ray subtitles (merging 1080p subs to 720p movie)
By prickly in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Jan 2012, 02:13 -
Merging .srt Greek subtitles with .mkv
By wolfmandim in forum SubtitleReplies: 1Last Post: 27th Aug 2010, 01:44 -
Subtitles not showing after merging with MKV
By CrimsonCobra in forum SubtitleReplies: 0Last Post: 10th Aug 2010, 21:43 -
Merging Video Segments with Separate Subtitles
By thomasj in forum Authoring (DVD)Replies: 2Last Post: 24th Apr 2010, 07:40 -
English subtitles have disappeared after merging clips with VOBmerge
By Josephine in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2010, 12:21
