can some1 plz tell me how to burn .dat files. thx.
Results 1 to 9 of 9
im fairly new to this stuff,i have been using thmpgenc on my avi files to convert them and nero to burn them.i would prefer to use thes programs to do it but i am not sure how with these. i had a look at the programs u recomended but they look kinda complicated.
well what about when you have to choose the template. such as pal,ntsc or ntsc film what do you choose because the dat file opens in gspot but it has n.a for the fps. also i have to extract the audio from the film in virtualdub but when i load it in virtualdub i get a error message.
k i have managed to burn it withput any guides or anything. thx for all ure help.
Hi, you want an easier way?
If you have a dat file you can rename it to have mpg extension.
Open my computer, click on tools - folder options.
Then choose the file types tab.
Find your dat and choose advanced at the bottom (win2k, dont know in xp)
there you choose always show extension.
Then click ok.
Find your file *.dat and rename it to *.mpg
Done."We cant be right all the time"
-Johnny Bergen
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 08:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 21:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
