I am still having problems trying to get my 2 hour F1 races that I have recorded directly on my HDD onto DVD in PAL format. I now have 7 such races on my HDD.
I have tried 2 different settings but the files still keep coming out too large.
My settings are:
MPEG-2 Codec
352 x 288 and/or 720 x 576
Bitrate 600Kbps
Frame rate 25.000fps
Audio Codec: MPEG-1 Audio layer II
Bitrate: 224 kbps
Is there something obvious in the above information that I am doing incorrectly?
I really don't know what I am doingeven though I have tried to read all the available information.
Any helpful comments would be very much appreciated.
Ron
Try lowering your video bitrate if you can...(2 hours of video=approx 4800kbps to fit on one DVD...)Originally Posted by Zippity
this info comes from here: https://www.videohelp.com/calc.htm
I too struggled with the "right" capture settings to get movies onto one DVD without "shrinking" them...maybe the guides at www.digitalfaq.com for capturing MPEG will help?
mastersmurfiejust a thought
mastersmurfie -
Try Half D1 resolution which is 352x576
Full D1 resolution (720x576) might look pixelated at the bitrate needed to fit 2 hours per DVD especially since there will be a lot of fast motion.
Half D1 should look fine though.
The resolution 352x288 is way too low for decent quality even at the highest of bitrates the resolution just sucks!
- John "FulciLives" Coleman
P.S.
When using Half D1 resolution (352x576) with a video bitrate of 4800kbps you will be happy to know that doing a straight CBR one-pass encode is all you need. Doing a 2-pass or multipass VBR encode at that resolution and bitrate is a bit overkill."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Thanks for the feedback
That option is not available on the WinFast TV 2000 XP pick listTry Half D1 resolution which is 352x576
Any suggestions?
VHS Capture Size Massive?
By donkey33 in forum Capturing and VCRReplies: 17Last Post: 24th Feb 2011, 01:40 -
Size to Capture VHS at for DVD
By MasterOfPuppets in forum Capturing and VCRReplies: 4Last Post: 3rd Mar 2010, 17:15 -
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 16:46 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 18:05 -
lower file size for a capture
By matneaves in forum Video ConversionReplies: 6Last Post: 1st Sep 2007, 12:34
