is there a way i can batch convert a whole folder of files to vcd without having to load up each individual file?
I.e. use batch mode with TMPGEnc.
After youve set a file for encoding - just hit CTRL+ALT+M and confirm adding project to batch. Repeat the same with next file. You can also do it without keyboard, on screen:
After you've added all files, just run the batch of jobs (CTRL+B), or do it on screen with mouse:
Need help converting a dvd folder..
By Soccerman77 in forum Newbie / General discussionsReplies: 6Last Post: 16th Sep 2010, 01:24 -
Converting a Folder into One .FLV File
By bk3134 in forum Video ConversionReplies: 1Last Post: 10th Feb 2009, 13:24 -
Converting a Video_TS folder into AVI
By HankE in forum ffmpegX general discussionReplies: 11Last Post: 6th Jan 2009, 15:48 -
Converting TS folder for iPhone
By osroubek in forum MacReplies: 1Last Post: 9th Oct 2008, 12:36 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54
