I want to convert an 25 fps avi to SVCD for playback on my Panasonic RV31 DVD player. Do I need to encode the entire SVCD as PAL with the 480x576 size, or is it sufficient to encode as a 480x480 NTSC SVCD with 25 fps?
I encoded a bunch of trial clips using PAL SVCD standards (including the 480x576 size) for playback on my standalone using different settings for the source aspect ratio to test for overscan. None of the clips played back normal--there was green pixelation and the aspect ratio was distorted.
What's the simplest way to do this? I don't want to do a framerate conversion if I don't have to. As far as I can recall, I've made PAL VCDs in the past but this PAL SVCD does not seem to work. Perhaps it's because my player is not equipped to play SVCDs without the VCD header trick? I'm not sure where I'm going wrong. Can I just encode as a NTSC SVCD and then specify "PAL" when I burn with Nero? What can I do to playback this file on my standalone?
Results 1 to 1 of 1
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 20:45 -
What DVD player is good these days for NTSC and PAL playback?
By b1lanc in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 12:56 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 10:10
